Need sugestions, steering linkage problem... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 09:15 AM
okeesignguy's Avatar
My drag link (I think thats the correct term) rubs against my headers as seen in the pix here and when i hit a dip or hole it bangs together...
I figure my options are...
1...heat and bend the steering arm down 1/4" or so...
2...add 2 additional header gaskets on that side...
3...do both...
before i do anything drastic, I wanted to ask you guys and get some other ideas and/or suggestions 1st...
also, I'm not sure if it would be a good idea to bend the arm or not...?
\Thanx for any help given
ID:	24718   Click image for larger version
Old 10-07-2007, 09:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I do not think it is a good idea to bend a steering arm if it can be avoided at all..Try the two gasket deal first...or you can get a header flange that is 1/4 or 3/8 thick and install that under your current header flange..I myself would try that first..Then if necessary do some bending or apply the hammer to the headers..
Sam
Old 10-07-2007, 11:34 AM
Sam
well...to be honest, I didnt care for the bending idea either...
thats why I asked here, to find out...
I DO like the flange idea, I hadnt thought of that...
I dont really want to hammer the headers because they show up so much on this car...
do you happen to know if this GM Performance engine with Vortec heads is a round or square hole exhaust head?
I just tried to find flanges on Summit and could find any...do you know where I would find some of these?
Anybody else got any ideas?
THANX!
steering arm/turning radius problem oldguy829 Suspension - Brakes - Steering 4 10-14-2007 07:01 PM
1955 Wagon Transmission Problem (Linkage) morga Transmission - Rearend 4 08-06-2007 03:53 AM
OK, now what..steering problem Bluepen Suspension - Brakes - Steering 9 01-12-2005 06:51 PM
1999 Tahoe 350 4x4 Steering Problem skyshield Introduce Yourself 6 11-22-2004 04:04 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
