Need suggestions on 9" Ford Rearend Narrowing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 04:33 PM
S10 Racer's Avatar
http://www.warsprints.com
As many of you know because I've asked a ton of questions here, I have an "89" S10 with a BBC 461, TH400 and a narrowed 9" Ford rearend. When I first built the truck, I opted to keep my driveline centered which offset the rearend housing to the driver side. I used leaf springs on this installation but now am getting ready to change it to a 4 link. Just so I don't have to cut these (special) mounts off and take a chance of destroying the axle tubes, I found another 9" Ford rearend to use. Now my question is, since I have to narrow the new rearend, would you recommend centering the rearend housing or keep the driveline straight? I noticed on the one that's in it now that a 4 link bracket would be hard to fit in the correct spot on the driver side because of the offset (see picture). Any help would be appreciated.
Thanks
Old 01-18-2010, 04:36 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I would DEFINITELY center the pinion, not the housing,
Old 01-18-2010, 04:42 PM
S10 Racer's Avatar
Yeah, that's what I have now and it makes it difficult for brackets but I can fiqure something out.
Thanks
Old 01-18-2010, 05:52 PM
Center it. Get your brackets on center and squair them up to one another ( 3/4" all thread and spacers made the length of your heim joints work the best)then tack them to your welding table as an assembly then fit the housing to them. This is the best way I have found to do them as long as you have a good flat and level welding table to work off.
Mike
Old 01-19-2010, 06:11 AM
big gear head's Avatar
High Performance Rear Ends
Are you sure that the pinion is suppose to be centered? Most GM cars and trucks have the pinion offset 1/2 inch from center. This puts the pinion 1 inch closer to the right side than the left. Measure your original rear end and I think you will find that it is not centered. When I narrow rear ends for GM cars and trucks with the original engine and transmission mounts I offset the pinion 1/2 inch to the right to keep it in the orignal location.
Old 01-19-2010, 06:29 AM
Rickracer's Avatar
1/2" offset will keep the u-joint bearings rolling a bit, not a bad thing, yet not enough angle to cause problems with power transmission. Ford goes WAAY overboard with it. I try to keep the horizontal angle to less than 1.5°, the longer the shaft, the easier it is to stay within that angle.
Old 01-19-2010, 07:10 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I would center the pinion.. The brackets can easily be made to fit.. Might look a little funny.. but it can be done..
Old 01-19-2010, 12:49 PM
bentwings's Avatar
bentwings
I wouldn't say exactly easy but it can be done. The Plasma or torch will get a work out unless you have a big band saw. I think I did mine 3 times before I got it right. Don't forget that with a very narrow rear end the shocks and springs are going to be very close together so your rear roll stiffnes is not real high. Torque will try to unload the right rear. A locker or spool will cover it up but not fix it.
Old 01-21-2010, 12:56 AM
68NovaSS's Avatar
Wiki Edits: 9
X2 with cewnter the pinion. You're going coilovers with a 4-link, right?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Question About 9" Ford Rearend STATUTORY GRAPE Transmission - Rearend 6 07-30-2006 03:31 PM
scored a 9" Ford rearend now I need posi.unit shockers69 Transmission - Rearend 3 04-12-2004 09:26 PM
ford rearend for 33? nick Transmission - Rearend 2 11-06-2001 10:58 PM
