Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need suggestions, randomly dying 02 Camaro 3800 DBW
Old 09-24-2011, 05:48 PM
LATECH's Avatar
LATECH LATECH is offline
put aa fuel pressure gauge on it and a test indicator light to the fuel pump power lead. Then drive it and watch while the problem occurs.If the light stays on and the pressure falls of along with performance then you have a fuel pump problem.If the power goes out to the pump and pressure drops off, then you have an electrical issue.Get busy.
