Need suggestions, randomly dying 02 Camaro 3800 DBW - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2011, 06:02 PM
New Member
Longtime lurker, rare poster but I've got a problem I can't seem to figure out and don't want to throw parts at it without a clue...
Friend of mine has an 2002 Camaro 3800 series II drive-by-wire. Recently replaced plugs (Factory recommended ac delcos), wires, cam sensor, air filter, cleaned MAF and replaced fuel filter. Car randomly dies going down road, no check engine light either when it dies or normal running. My friend took it to a shop that wanted $900 to do fuel pump, but I don't believe the problem is fuel pump as it has good fuel pressure running and during/after it stalls out. Sometimes I'm able to keep it running by flooring the pedal and it chugs a bit, then revs out of a stall, and sometimes it will just die anyways. This happens basically at random, either going down road or sitting idling, but no more than 15 minutes go by without it happening. I tried pulling vac line off of fuel pressure regulator with engine running and it doesn't reek of gas or look moist even after several minutes of running. Car will always restart after dying, but sometimes I need to floor pedal in order for it to restart easily which makes me suspect ignition more than fuel as the reason its dying
Car idles smoothly, check engine light does work (at bulb check it turns on, then shuts off when engine is started), and has no stored or current codes. I tried pulling ICM and had O'reillys test it and it came back fine, I don't want to throw any number of expensive parts at the car without some good reason to believe that is the problem, but at this point I'm suspecting ECM or ICM, but both of those are expensive and I don't want to pick wrong as we're working with a limited budget here. Any bright ideas, or ideas as to how I can be sure which is causing the problem? I have a code reader but not a fancy scanner, though I could probably borrow one.
Old 09-23-2011, 06:53 PM
Last journal entry: gettin closer and closer
This sounds like a problem my friend had and it ended up being the ignition. dont know why they go out but they do. Id try it out.
Old 09-24-2011, 04:48 PM
LATECH's Avatar
put aa fuel pressure gauge on it and a test indicator light to the fuel pump power lead. Then drive it and watch while the problem occurs.If the light stays on and the pressure falls of along with performance then you have a fuel pump problem.If the power goes out to the pump and pressure drops off, then you have an electrical issue.Get busy.
1979 Camaro, need converter rear gear suggestions mikey1476 Transmission - Rearend 2 06-12-2011 09:52 PM
94 lumina 3.1 stumbling in park randomly fast68 Engine 4 04-05-2009 01:46 PM
1998 camaro 3800 firing order kylestep Engine 1 07-17-2008 08:22 PM
351C randomly shutting off.... Steve-0321 Engine 5 03-29-2006 03:04 PM
Suggestions? 67 Camaro needs balance of power/mpg. MadJester Engine 24 12-13-2004 06:52 AM
