Need suggestions for sbc 1 pc oil pan gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2007, 08:00 PM
Last journal entry: BoB
I have a 77-79 sbc 350 drivers dip stick. I want a one piece, thin front seal oil pan gasket. I have a fel-pro FEL-PRO OS34510T (thick), that will never seal with my stock timing cover and stock oil pan. Summit has fel-pro OS34509T and FPP-1885 gaskets that might work. Which one do I order? Thanks for your help, Tom
Old 12-02-2007, 08:30 PM
GMC boogie's Avatar
The thick front pan seal(OS34510T) is correct for a 75-79 oil pan. If it is too thick,you must have a pre 75 oil pan which takes the thin front seal. Timing covers are the same.
Lay the pan flat(pan rails down) on the floor and measure from the floor to the highest point at the front seal mating point. The distance is 2 3/8 for the thick and 2 1/4 for the thin.
350 Chevy oil pan leaking gasket Ed Baltera Engine 14 08-05-2012 02:17 PM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 08:21 PM
Beware of one piece oil pan gasket for a Ford 460..... onebadmerc Engine 0 12-30-2006 07:00 PM
New pan gasket without raising engine? rapsag Engine 14 04-21-2006 03:49 PM
