Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Tank Sender for Custom Gas Tank....
Old 11-05-2002, 05:49 PM
Deuce Deuce is offline
Post
Sending units come with different values ( 80 ohm to 240 ohm ) and others. The sending unit MUST match the fuel gauge for correct readings.
Stewart Warner and Ford Motorsport uses the 80 to 240 range for their fuel gauges.
You also have differnt lenghts (for different depths of tanks) and left hung and right hung units.
