Re: Re: Need three questions answered please!
Here's one, , If you find yourself wanting to wet sand a little problem...use a little Windex instead of water with your sandpaper...you'll see [/B][/QUOTE]
*************************************************8 8
Did not know that, will try.
Another thing that works good if your wet sanding in a rush, Is wet the paper with wax and grease remover, it will normally let you get on it in about half the time as with water. What i mean if the base needs to set 20 minutes to sand with water you can use the wax and grease remover in about 10 minutes --(not waterborne type)
BUT, only wet the paper and not the car, you puddle it you could be in trouble.
Not for the faint hearted for sure.
Of all things learned this from a ppg rep about 12 years ago.
