need tie rod end suggestion.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 08:04 PM
user151's Avatar
No luck over at the other place, so....
On my current A coupe build I have 41 spindles on a dropped axle with split bones. The tie rod will almost go on, above the bones, using the usual Ford tie rod ends (A in the drawing)...
A tie rod end with an offset shank would work. I recall tie rod ends with an offset shank (B in the drawing) but don't know if they are available with the Ford taper and thread.
Anyone know a part number for what I am looking for? And the more offset the better.
Yes I can bend the steering arms but this looks like a simpler solution. Thanks for any suggestions.
Old 06-12-2009, 08:35 PM
fordinator's Avatar
recycled rodder
mid to late 60's falcons have them.
part ES360RL on rock auto if you wanna see it.
I'm using them on one of mine.
Old 06-13-2009, 05:24 AM
user151's Avatar
Thanks!
Looks look what I need, I will check them out. Thanks.
Con. Rod little end "blued" Arcuden Engine 4 10-14-2007 06:04 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Has anyone used an S10 rear end in a rod? 48ChryslerRodder Transmission - Rearend 25 10-09-2005 08:17 PM
can't get the tie rod loose trident Suspension - Brakes - Steering 4 05-21-2005 11:02 AM
tie rod end stud too long? guba_unus Suspension - Brakes - Steering 2 01-06-2005 08:08 AM
