Need torque converter! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 05:43 PM
have a 350-5.7L sbc. making major upgrades to engine! new cam, new manifold, new carb! want torque over hp. i guess a 3500 stall would work? if u have a better suggestion let me know! wanting used but in good shape!!!!
Old 10-15-2006, 06:44 PM
jalopy45's Avatar
Get online or call ATI http://www.atiperformanceproducts.com/ or Hughes http://www.hughesperformance.com/ ,, or similar company it will be a lot cheaper and you'll be a lot happier getting it right the first time. Be prepared to give them as much info as possible, ie, engine size, rpm range, transmission, rear end ratio, carburetor size, cam and intended use.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
Headers & torque converter Questions Mustangsaly Engine 19 09-27-2006 07:39 PM
torque converter banging??? Flywheel or tranny?? boneyard Buick Engine 5 09-04-2006 03:07 AM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
