need tricks or ideas for more power - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2014, 09:16 PM
k so this is for all the guys that do this on a daily basis. i have a 70 swb (hence the name) but i have rebuilt the motor and the tranny is rebuilt also. motor has over size cam, dome pistons, and high compression. i got some parts from a guy that quit running dirt track. all parts were brand new parts. i dont like running used stuff tranny is a turbo 400 all stock. new edelbrock carb. i would like to add power to the truck. i have dreams of making the truck a nice hot rod and i guess you can say im in the process of doing so. so my question is what can i do and what parts can i use to make power (torque/hp)? i cant spend a whole alot of money right now but i am saving for the bigger stuff. what can i do without breaking the bank? thanks in advance.
Old 01-01-2014, 09:22 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You did not give us any info we can use to help you. We need to the specs of the parts you have in the motor now and the specs of the parts you got from the other guy. Just stating "oversize cam" or "dome pistons" does not tell us anything. You have to be more specific.
Old 01-01-2014, 09:27 PM
i dont have all the specs. someone rebuilt the motor for me on a work trade. i keep kicking myself for not getting all the info like i know i should have. i was just looking for ideas on what kind of extras to add. i dont really want to dig into the motor just yet. i use this truck for my daily driver
Old 01-01-2014, 09:36 PM
S10 Racer's Avatar
Do you know what heads are on it? Casting #?
The problem is that everything has to work together to make power and by not knowing what you have now, we are just guessing and could hender performance instead of helping.
Old 01-01-2014, 09:42 PM
i know they are stock heads but dont know casting #. Damn i should get all this info together! lol
Old 01-01-2014, 09:43 PM
S10 Racer's Avatar
What parts did you get from the other guy? Can you post some pictures of them so we at least know what we are looking at?
Old 01-01-2014, 09:50 PM
just the cam and and pistons. most everything is original. this truck sat in a garage with the front end wreck for about a 15 yrs. i will try to get more info for y'all tomorrow. sorry im kinda new at doing a complete rebuild myself. always been in the background doing the easy stuff. thanks for the paitence though
Old 01-01-2014, 09:59 PM
S10 Racer's Avatar
The problem there is not knowing what parts you have to work with. I doubt that those pistons or cam will do you any good. Most Sprint car guys use a number of different stroke motors and that is based on the crank, rod length and pin position of the piston. Also, some pistons made for Sprint cars are custom made. The cam "may" be usable but again, those for Sprint cars are designed for circle track racing and not street use.
Old 01-01-2014, 10:13 PM
thanks. i appricate all the help. i will rethink the way im goin with this. i have been thinking that i want redo the motor anyways top to bottom. guess now i have a reason! this time i will record all the info!
Old 01-01-2014, 10:49 PM
techinspector1's Avatar
Wiki Edits: 326
If it's a flat tappet cam, the only use for it is either in the motor it came out of or as a doorstop. You cannot use a used flat tappet cam in another motor. Well, you can, but you won't like the results.
The chances of two different blocks being machined to the exact degrees, minutes and seconds of angle on all 16 lifter bores is akin to winning the Powerball lottery.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
crussell85 (01-02-2014), hpengineprep (01-02-2014)
Old 01-02-2014, 09:37 AM
S10 Racer's Avatar
True & True. I was assuming it is a roller if it came out of a Sprint Car. My bad...
budget ideas to get lots of power with my 350ci chevy302z28 Engine 26 11-09-2006 03:54 PM
performance tricks ELFEGO BACA Engine 9 07-17-2005 07:04 PM
Door Wire Loom ideas/tricks JhnBrackett Interior 2 05-10-2005 05:52 AM
i need the most horse power for street performance out of a 350 rocket any ideas olds86rocket Hotrodders' Lounge 2 02-19-2003 08:07 PM
Cruel Tricks... Weimer Hotrodders' Lounge 7 10-02-2002 04:55 PM
