Need the truth...firebirds and camaro's - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 05:22 PM
So I have a 76 firebird formula that I'm restoring, its my first resto project. I can not find so many parts for it and its really frustrating. I have been told that the parts are interchangeable between camaro's and firebirds. I need to know if this is really true before I drop a lot of cash on camaro parts.
Parts I'm looking at:
Radiator core support
Lower control arm bolts
Spindles
Bolts for body panels, front fender wells
Thanks in advance for your input.
Old 11-07-2011, 07:15 PM
You will find that the body panels are a little different. The front inner fenders are a little different because the firebird had fifteen inch wheels and the camaro had frourteen. The wheel wells are a little bit bigger on the firebird. Radiator support is different because the camaro used a different hood and front cowling.
The things that I know for sure are the same are the front subframe and unless you are dealing with a trans am all the suspension parts are the same, fire wall, floor boards and all inner structure panels the same, the roof is the same and all of the glass is the same.
Go ahead and build it. Firebirds are popular and there is just as many after market parts for them as there is camaros.
Old 11-08-2011, 05:58 AM
Another question
The early 70s firebirds{70 -74}..do they have the same front suspension and sub frame as the 76??
firebirds and camaro dependability bullheimer Hotrodders' Lounge 39 11-30-2012 11:31 AM
GM's Firebirds {Turbine} 3 generations Rob Keller Hotrodders' Lounge 1 07-23-2008 11:38 PM
Firebirds larry wilson Introduce Yourself 2 12-07-2005 02:33 PM
Are Camaros and Firebirds Compatible? unstable Suspension - Brakes - Steering 5 08-08-2003 01:59 PM
Camaros and Firebirds? Halloweenking Hotrodders' Lounge 18 10-17-2002 10:22 PM
