Need Valve to shut off heater
Dudes!
I bought a Camaro heat/air (inside/outside box) with blower! (Woopie! HEAT! What a concept!) ...I'm in Michigan....kinda cold out there.... I'm cutting up this thing to put into my 39 Pontiac, trying to modernize the heating system which needs it bad...because THERE WAS NONE! This summer it was hot inside the car, so I figure to shut off the heat next sumer I am going to need a valve or two...turn off the hot water! I want something that I can control from inside the car...my preference would be a valve that operates by 12vdc, and has 1/2" barbs inlet/outlet. Then I just slip my hose over them valves and wire up to switch. BOOM ZOOM I can shut off the heat! Do you hot rod guys (with heat) know where I can get two such valves? And Merry Xmas rwruther |
Vintage Air sells a few products that would solve your heater problems:
Here's a fancy electronically controlled valve setup - MSRP $ 89.00 This could be setup with a toggle switch instead of the rotary control. The electronic part of this servo valve is not weather resistant, so I don't think these would fare too well in the engine compartment. I only use them inside the car. ![]() And here is a much simpler, manual valve - MSRP $ 18.00 They are also available from any auto parts stores (maybe for less $). ![]() My favorite water valves are "H" shaped and have connections for BOTH heater hoses. When they're in the off position, they actually bypass the heater core and keep the coolant circulating, rather than just shutting off one hose. They are available in manual or vacuum controlled versions and can be purchased from any auto parts store. You have a lot of options. Good luck. |
Depending on how your heater is ran you don't want to just dead head it against a valve. I like the idea of bypassing the heater. The heater in some systems works outside of the thermostat loop so the heater is always flowing water, this makes your water pump work less when the thermostat is closed because it is able to circulate water.
This one looks good and once installed you wont have to remove it. http://www.jcwhitney.com/Heater-Acce...2306_10101.jcw
66 Mustangs (etc) have a cable operated valve. You could sneak a choke type cable under the dash (I did) or in the glove box.
Mopars of 60-70s have a manual H type valve that automatically bypasses back when you turn off the water. So do some of the newer Ford cars but they are vacuum powered. Electric? If you are lucky you might find a parts store guy with enough knowledge to find the valve you need. Remember stopping that water flow through the heater in the summer makes the engine run cooler since all the water is getting through the radiator. 1/2 inch is pretty small. Most are 5/8" hose. Also consider a flow restrictor at the manifold output to prevent blowing up the heater core when you rev the engine with the thermostat closed. The factories put flow restrictors. If you need to make one, cut off a bolt of enough diameter that fits tightly in the heater hose, cut it off about 1/2 inch long and drill a 5/16 hole in it to reduce the water flow. This also reduces flow in the summer to prevent reduce the amount of bypass in a full flow heater core for summer cooling. YA, I often wondered why they use 5/8 and 3/4 hose and then restrict it to 5/16. Never will figure that one out.
If you dont run a thermostat this would probably work without blowing your hose off.
Vacuum http://www.nostalgicairparts.com/air...-valve-514.php Cable http://www.nostalgicairparts.com/air...-valve-114.php Last edited by Jake_Dragon; 12-26-2008 at 07:13 PM. |
Most late 60's ford trucks use a cable operated heater valve which works very well. I have a 69 corvette that originally did not have a heater valve, they simply closed door flaps under the dash to re-direct the heated air outside. Really a stupid system to have hot walter through the heater core all the time. Napa sells a manual scerw valve that goes from the water pump to the heater hose. It has a simple valve that you can turn the water off or on very quickly. Works great! I think it was about 8 bucks. Simple is good!
| Recent General Rodding Tech posts with photos |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| cam question, any truth to this? | 406 ss monte | Engine | 9 | 03-30-2008 11:28 AM |
| Bad Air Valve | black66 | Electrical | 8 | 04-12-2005 12:44 PM |
| Fuel Shut off Valve | longt | Engine | 5 | 02-09-2005 02:27 PM |
| Heater has mysteriously stopped working. | HotRodMan | General Rodding Tech | 8 | 12-29-2003 04:38 AM |
