Need Website for gear ratios - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2006, 09:40 PM
western star's Avatar
A few months back someone posted a website that tells you gear ratios using rpms, mph, tire size and you could even select which auto transmission you were using. I lost that information and would like to calculate it again. Any help would be appreciated.
Old 08-29-2006, 10:28 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
This may help
http://www.angelfire.com/fl/procrastination/rear.html
Old 08-29-2006, 11:36 PM
Nope that's not the one however fun to play with.
Old 08-30-2006, 09:18 AM
larryblack's Avatar
Certified Lead Foot
Go to www.lightlineofla.com and enter. On the lower left bottom you will find the tire and gear calculator.
It is for 4x4's but if you put a 1 in the transfer case ratio it works just fine.
Old 08-30-2006, 09:22 AM
SSon18s's Avatar
try www.interco.com
Old 08-30-2006, 09:32 AM
Frisco's Avatar
Glad To Be Here
Go to Randy's Ring & Pinion
This one works very well.
Building a Website edge Hotrodders' Lounge 5 06-12-2006 12:59 AM
Dynamometer central Florida Jake_Dragon Engine 9 05-22-2006 02:02 PM
Designing a Website WakBordr7387 Hotrodders' Lounge 8 04-30-2006 08:22 AM
Lightweight independent read end with wide ratios? d1camero Suspension - Brakes - Steering 5 06-22-2005 12:42 AM
