Need window pattern for 1939 chevy 2D - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2013, 11:48 AM
I have a 1939 Chevy 2D sedan that need glass for the doors.
I thought I saved them when I got the car but they may have been
shot out.
Any way, I would like to know if some one could send me a tracing of their
glass so I could get some windows made...
I know this is a lot to ask, but it's worth trying.
Old 03-25-2013, 09:21 PM
Need window pattern for 1938 chevy 2D
www.fillingstation.com in Lebanon, OR. Great tech folks and also probably have what you are looking for. If not get back to us here. We have a lot of talent on this net.
Normbc9
Old 03-25-2013, 09:39 PM
33Willys77's Avatar
1/4 inch plywood works great for glass templates. Start with corregated cardboard and trace it to plywood. The plywood does not bend like cardboard so you know you have the right fit. Here, the glass companies will actually come out and make thier own patterns and fit the glass themselves. Sure makes it easier. You may want to try your local glass companies and see if they will do this.
Old 03-27-2013, 10:32 AM
Thanks for the input.
I'll try making a template.
Old 03-27-2013, 05:49 PM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Probably not the same as sedan huh??
Old 05-19-2013, 11:29 AM
Ok.. I made my pattern but now I'm not sure how much of the glass (if any) should be showing when the window is all the way down.
I tried to find pictures on the the web but could not find a good closeup.
At this time the glass would be below the door in the front and back but
some of the glass would be sticking out close to the middle.
I attached some pictures. I hope they show what I mean.
ID:	74134   Click image for larger version
Old 05-19-2013, 10:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I wonder if the window operator system has any adjustment to allow the window to go down that last little bit??
Sam
Old 05-19-2013, 11:32 PM
I have a full set of glass out of my 39 Chevy coupe on a shelf in my shop. Would be glad to make and send a pattern. My new glass sits just flush with the top of the window fuzzies. PM me. Dave
Old 05-20-2013, 07:06 AM
Hi OneMoreTime,
I could still take some off the bottom of the pattern I'm making to make it lower.
Old 05-20-2013, 08:10 AM
Wiki Edits: 3
That part of making patterns is to get the part to work just right to suit you..Good one to take a bit off of the bottom..
Sam
Old 05-20-2013, 07:21 PM
Yes, once you get the "glass" fitting the track, and shape. In order to get the proper rolldown height, take it from the bottom. You want the highest part of it to be flush with the outside of the door. (when rolled down.
1939 Chevy avila39 Body - Exterior 0 02-25-2011 11:34 AM
1939 chevy Retsfc7 Introduce Yourself 1 01-27-2011 03:39 PM
Adjusting Vent Window on 1939 GM Body JohnTN Interior 1 09-30-2006 09:25 AM
1939 Plymouth 5 window coupe conversion 39Plymouth Introduce Yourself 3 12-30-2005 07:55 PM
