turn signals
Black Horn Light blue Left front turn signal Dark blue Right front turn signal Brown Hazard flasher Purple Turn signal flasher Yellow Left rear stop light and turn signal Dark Green Right rear stop light and turn signal White Stop light switch. Hope this helps. Bob |
Black Horn -----------from horn button to horn relay
Light blue Left front turn signal Dark blue Right front turn signal Brown Hazard flasher---------From flasher----constant 12v Purple Turn signal flasher-----From flasher----12v with key on Yellow Left rear stop light and turn signal Dark Green Right rear stop light and turn signal White Stop light switch.------from switch----12v with brake pedal depressed Hope this helps. ------------------------------------------------------------------------- May be 2 more wires in that switch a pink wire paired with a black wire These two wires are for the "Key in Ignition" buzzer, in the event you have that. EDIT For what it is worth, All of GM turn switches from about 69 up into the late 80s are pretty much the same wiring.. (includes Dodge truck tilt columns to about 92) Somewhere in the 70s they changed the connectors so early and late connectors will not mate, but I believe that GM can still get the jumper to mate the two connector bodies |
Yes I looked at your location before posting and was hesitant to mention the rain here. I was hoping you guys would get some rain from tropical storm Lee, but from what it shows on the national weather service 7-day forcast for San Antonio, you'll likely be dry a while longer.
Hopefully you'll get some H2O soon.
| Wiring Turn Signals On 57 Chevy | NCC1701D | Electrical | 3 | 04-14-2011 11:26 PM |
| LMC truck, great turn signals-lost diagram | Footstomper | Electrical | 1 | 01-29-2011 11:10 AM |
| Turn signals to brake/running lights conversion (motorcycle) | weirdbeard | Electrical | 3 | 08-08-2010 03:16 PM |
| 1963 cadillac brake lights and turn signals Help Please | colwoodshane | Electrical | 6 | 03-07-2010 01:24 PM |
| Wiring Tail Lights & Turn Signals | horvath | Electrical | 15 | 04-30-2003 05:04 AM |
