need wiring harness help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2009, 09:59 PM
hey guys i am branden and i am from shawnee oklahoma. i am building a 87 s10 with tpi 350 and th400 tranny does any one know where to get a affordable wiring harness without emission and mass air and the best fuel tank to use . hope someone can help i am knew to the fuel injection swap thing carberaters are always easier but where is the fun in that.
Old 10-29-2009, 10:39 PM
wiring harness help
I would recommend to check out Painless Wiring they have a lot of things to offer. It may be a good idea to check out the computer of the vehicle that the motor came out of if possible. This is a great project but more than I want to do. I plan on sticking with an MSD set up with a carb.
Old 10-31-2009, 01:45 PM
snkbyt's Avatar
ASE Master
Last journal entry: Wireing
Buy a harness and computer off ebay. I just did. Then get a book called TPI swappers guide. Get the MAP system from 90-92 TPI. The earlier uses MAS but from what I can figure the MAS works better for a highly modded engine. MAP has to be with a cam duration less than 220 for good tuning. The memory cal can be sent in and be reprogrammed for the engine. I'm using the MAP since it looks better in a street rod. I just had everyting on the manifold polished.
Building a new Dodge wiring harness, need help DaSouthWon Electrical 3 03-01-2009 05:39 PM
POWER accesory wiring harness 91vette Electrical 13 04-11-2006 05:21 PM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
ford wiring harness akm Electrical 6 03-13-2004 10:25 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
