need wiring help on 74 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 03:07 PM
car started 1 hr. ago but then i rewired the dist. and changed cap, roter, points, condenser and now it wont start. i got juice at the batt., alt., both sides of coil(when key is on) and i got spark at coil an no.1 plug but still no vroom-vroom. ne1 help?
Old 03-03-2006, 03:30 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
you said you rewire the dist.? did you do the plug wires one at a time or yank them all off at once? i'd check to make sure you've got them on the right firing order.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 03-03-2006, 03:31 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Need more info..What car, year/ model, Size engine, type of ignition.
Doc
Old 03-03-2006, 04:39 PM
plug wires r right.
its a 1974 chevy nova with a 4 bolt main 327 out of a 68 corvette. all the plug wires r right, juice in battery, gas in tank, spark at coil,plug wire, and plus, replaced old condenser and points thinking i had defective new ones. engine cranks but wont start.
Old 03-03-2006, 05:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check the points, Should be 15 to 17 thousands, They may be too wide to support combustion.
The Fire order is 1 8 4 3 6 5 7 2 ...Double check this..5&7 can be back wards because they are the only two that are next to each other on both ends of the wires..This usually causes backfire and poor performance.
What color is the spark? Cold blue (good) or Anemic white/yellow (bad)
I assume you did not disturb the distributor (pull it out..) correct?
To include or exclude the ignition system, spray some starting fluid down the carb..(or dump some gas in) and try to start it...If it won't start it's Ignition. If it does start It's fuel delivery ..
If it doesn't start check the coil..get a DVOM, and set it foe R X 1 (calibrated to 000) and measure the primary side..It should read less than an ohm, but more than 000..outside of those ranges, toss it and get a new one.
Next set your meter for R X 10K and measure the secondary, it should read between 10,000 and 11,000 ohms. Out of this range toss the coil..
Check your Rotor button..(Don't shoot me..I've done it..) Make sure it's in there! Then use your meter on each end of the tang..it should read 000, then move the tang up and down, It should not change readings..you can just try your old rotor back in there too..
Be sure the pigtail on the points are not grounding out..and that the ground pigtail is in place.
Be sure your secondary Ignition is in place, this provides power to the coil while cranking..(when the key shuts off the rest of the car.) to quick test, just run a jumper from the battery to the + side of the coil..and try it..If it runs you need to repair or install an secondary ignition wire. You will have to pull this jumper off to stop the engine.
Make sure your Ballast resistor is in place and working. With the points closed, or jumpered shut, measure the + side of the coil , It should read between 6 and 9 volts if it is working. If it's 12 volts it's not working, and may have burned up the coil..points will burn out rapidly also.
That should find the problem.
Doc
Old 03-03-2006, 06:56 PM
me again
everything you said to check i checked and it was right on, except yes i did pull the dist. so i could replace the wire that goes to the coil. i did get it back in right but then i thought maybe i put it in 180 out so i changed it but that was actually wrong so i put it back and i still have no vroom-vroom. about ready to put my shotgun to it !!!
Old 03-03-2006, 07:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Pull number 1 plug, Bring it up on compression, TDC, with the timing marks lined up and both intake and exhaust valves DEAD closed..Pull your cap, and verify #1 Plug tower (should be between 5 and 7 O'clock position) Is dead on #1 plug tower..
If this and all the other steps are correct, and NOTHING was overlooked, you have an Induction problem, not an Ignition problem.
There is nothing left electrically to check, with the exception of the condenser, you can pull it off the points, and try it, It will run briefly without it. If it's shorted, can kill spark.
Be sure your plugs aren't so wet they can't fire..and make sure the Dizzy is actually turning.
Doc
Old 03-04-2006, 09:49 AM
did all that
did all that but i still cant get it to start so i just dont know. i guess i have to just take it to a shop and pay a fortune to fix it. OR sell it !!! want to buy it?
Old 03-04-2006, 10:53 AM
hey doc
maybe you could just call me at 541 513 6017 then we could just talk about it ok?
Old 03-04-2006, 01:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Pull the plugs, Do a compression test..
Jack the throttle wide open, and crank at least 3 times on Compression stroke before you take the reading. If it reads lower than 125 on all cylinders you have some mechanical problems. (Valves/Rings)
If it reads REAL low all the way around, Like 75 to 90 , your timing chain has jumped. You will need to reverify that the #1 TDC, Compression stroke, Both intake and Exhaust valves are closed, and the timing marks line up. If you can't coordinate those, For sure the timing chain has jumped.
Your compression , Normally , Should be between 125 and 150 +/- 10% all the way around.
Try advancing the Distributer all the way counter clockwise, and see if the car wants to try to start, or if it kicks back against the starter, If it does it's about a tooth off on the distributer setting.
Doc
Wifes 74 nova project Larry Martin Introduce Yourself 4 01-27-2006 05:41 PM
diagram of a 1972 chevy nova wiring harness darnell25 Electrical 2 09-14-2003 05:14 PM
74 Nova response 74 Nova Engine 0 02-17-2003 11:28 AM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
more power for 74 nova CombatWombat Engine 15 10-12-2002 09:10 AM
