| The Following User Says Thank You to bygddy For This Useful Post: | ||
The Camaro Kid (12-28-2012) | ||
Lets do some Math
SHP castings $400x2 plus $400 for mild porting,lets call that a stage 1 port job.= $1,200.oo what I get is a casting that will flow 235 cfm(more potential but thats all I need for a mild engine) and have a 75-80% exhaust ratio.I get a flow chart so I can match my cam. OPTION 2 305/vortec/other GM castings=free or less than $50.oo w/e buy a head porting kit?,,, $100.oo buy a couple books,,,,$75.00 Porting power tool,,,$150.oo (or more) time??? read the books,n/c but 10 hours invested,lets call it enjoyment=still co cost 40 hours labour to port heads to what we think is equal to my stage one port job I paid $400.oo flow numbers= no idea,but better than stock,no idea if they are even but they look good. Your labour value? you fill the number in.I would take that 40 hours and do overtime at what Im good at and get that money as a return or bonus towards my engine build. You save $400.oo dollars for 40 hours of your time. If you earn 10 bucks an hour then all is well. The $900.oo you save comes at the cost of 40 hours of your labour and you end up with cast iron castings,that might be equal in flow. Next time you want to step up your power you will need new bigger castings,,,my castings have lots left yet. If you know for sure that mediocre performance is all you want,then port your own heads,enjoy the project. |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
Camaro_Nut2001 (12-28-2012) | ||
I wish you the best of luck and hope you enjoy the project as it unfolds as much as the finished product.
There are always many correct answers,choose yours wisely and you will always have good results. |
Hilarious. I don't know what Canada puts in the water up there but it should be investigated. Every Canadian that posts on here think the 416 305 head is the best thing going. Give it a rest.
You think a home porter with a die grinder and some stones is going to be able to match the flow of what GM engineers consider their best port design ever? Without a flow bench? Especially a beginner? Don't be calling anybody an idiot after posting that garbage. On edit, I see you backtracked a little bit. All the things you mentioned while porting your heads are very valid pluses to what you did. There's just too many good heads out there at reasonable prices to mess around with those heads, especially when you consider you can port them all you want but you're still stuck with the old chamber design. Quote:
I'm going to tell you what RHS told me behind closed doors yrs ago.That they invested huge into a CNC machine and hrs apond hrs of R & D to develop their own program. The thing is even after all the yrs they have been porting heads and with their most experienced porters,port to port matching was only within 25%. The labor hrs for that was out the door costs.More or less out of control and nonprofitable.That with their 5 axis CNC porting port to port matching was now within 5% and they could complete a set of heads start to finish in 8hrs.
It isn't the finish of a port that is most important nor the "rated intake runner size". In fact to smooth port true Vortec heads is counter productive. The rough surface is apart of what makes them Vortecs.What is most important is the cross section of the port and it's shape. So what's my point about hand porting??. Well if you get a port to run port to port 25%,you just got very lucky because you just achieved the skill level of RHS's best hand porters.Do I suggest you run out and buy a CNC $250,000 machine??. Nope. Do I suggest you do a search on how to build a home use flow bench??. You bet I do. Flying blind is a bad end result. I am trying to make you aware of RHS's research and what you can expect with hand home porting. Now 305 on 350's??. Increased SCR with under the best circumstances don't flow enough to make them worthwhile. Just the plain simple truth. |
whene reringing an older engine using the origional heads, is it a bad ideah go just clean up the ports on heads? ive always knocked down the tall casting ridges only on the intake ports and polish the exhaust ports smooth and work a little angle out of the runner but thats it. i never know if it workds or doesnt work. i figure it cant hurt.
Budgets are stupid, spend what it takes to have the best no matter how long it takes. Don't home port anything, cause clearly the results will be mediocre at best. I think that about covers your views correct? Excellent |
0trbo4myCHEVUICK (12-29-2012) | ||
Don't have the time right now.The rest of the story is how we went from a very scarey to drive straight axle Vega with a junk yard engine to a 632 50K engine.It's all positive posts and a outline how you could easily do the same thing.
TTYL |
lol!!!
you guys must think Ive never ported heads,,,When I was in grade 12,metal work class I was using the milling machine as a personal head porter. I was 1/2 way finished the second head when the shop teacher stopped my project.I finished the last 2 ports with an electric drill,cause thats all I had. I later put those 2.02 straight plug camel bump heads on a 283 with a used(yes,used) duntov 30/30 cam. Back then,people believed that you would lose torque if you used monster 2.02 valves on anything less than a 350 race engine.People also believed you needed small exhaust,2 inch duals,or you would lose torque,,,rofl.... So I had a 283,solid cam,muncie 4 speed,2 1/2 inch exhaust back in the early 70s. Ive moved up since then. I would never discourage anyone from self porting or any other thing you can do yourself,just make sure its worth it. Now I see people building 383s like they are magic and trying to use cheap parts to make power. All good,if thats what you want,or just want the experience. Im just at the point where I wont work an extra 4 hours to save $50.00,but I will spend an extra $50.00 for a better part that makes the same power. |
| Need ya'lls opinions on SBC heads | Camaro_Nut2001 | Engine | 38 | 11-17-2012 08:32 AM |
| need advice ...bad. | rrmike | Hotrodders' Lounge | 1 | 04-11-2006 01:46 PM |
| Bad advice | lluciano77 | Engine | 28 | 03-09-2005 06:33 AM |
| Just bought a 1966 440 pretty bad shape. | Journier | Engine | 4 | 06-07-2004 02:21 PM |
| Need timing advice real bad | 54 Chevy | Engine | 4 | 07-25-2002 07:09 PM |
