When we stop counting 17 completely different 9.90 cars in 20 yrs that where purchased as incomplete financially distressed sales rollers and turned over in a resale for a profit after finishing them and a yr of racing turning it into a winner with the slips to prove it. Very good sponsorship deals for all but three yrs.Sales of overstock parts and refurnished high performance hard core parts.Built and sold engines for both the street and strip.Close association with many of the parts manufactures.In the business for what,40 yrs.Winner of a national event in Canada.Top 4 finish at a IHRA regional event.Current car has a 632 BBC Alky on the bottle alittle which we are very proud of to after all these yrs have built ourselfs up to.It's a 50k engine.Back up engine is a 565 BBC.Either my partner nor I drive the car anymore.There is a driver.Sum that up is both of us have gotten too old. Me I have been involved in cars since I was 10 yrs old and I am 65 now.So what's that??.55 yrs.Came out of the ranks of mid ET bracket cars of various brackets.And yes I sure do miss that.Huge supporter of someone who is building a low 13/high 12 second car.Lots of rounds of competition and tons of fun.Many,many street hot rods over the yrs. That's about it for now. |
I have done a lot of four valve and five valve heads in my day and i used to charge a crap load of money for it. To guys that had flow benches trust me 5% difference in ports would result in never hearing from that customer again cause his heads would perform less than stock heads. Stock chevy and ford castings are so bad its easy to pick up a few hp. But i dont recommend you do it at home first time on your only working set of heads. Either do it rigth with a stack of practise heads and get the proper tools or get better heads. Knocking down ford exhuast bumps or other large casting marks is easy but most people go way to far and loose sight of the job before the first port is complete. Its not hard to do a good port job at home but it does take some practise. And lots more practise and sometimes even a really bad port job will make some good power. |
| The Following User Says Thank You to bygddy For This Useful Post: | ||
Camaro_Nut2001 (12-29-2012) | ||
And that wasn't a slight on anyone else's opinions, or offer to help....to be clear....there's many many talented, knowledgeable guys on here....I mentioned the 3 that have helped me tremendously, and clearly know their sht, and have had to listen to "I need help" pm's from me and have taken the time to do so....
Dave |
I can tell you this, not one port on any nascar 357 is the same and there is a purpose for it.. a cnc'd head with mirrored ports will slow the cars.. with a single plane intake.. let them run 8 throttle bodys over each cyl. then mirrored would win out.. not untill |
Yeah but NASCAR has always had odd ball combo's.I bought at the Indy Drag Racers auction a NASCAR 4.3 and had contact with them until it was done.It is the reason why the teams start with rough forgings or a blank slate. We had been going to that auction for yrs and there was time when Indy cylinder heads ran the event.We got to know them and saw some of their exotic workmanship.Just works of art.
No, 1Gary, that was not directed at you. And no, bygddy, it wasn't directed at you, even though for some reason you felt you had to reply after I said that the things you enjoyed with your boy while porting the heads justified it, but if you want' to continue to make a pissing match about it, by all means have at it.
It was directed to F-Bird88. I'd like to see the qualifications that he feels entitles him to talk down to people and say that his builds are the gospel. From what I've seen, he's no more qualified than anybody else. He just posts the most and the "loudest". |
And what it cost you total cost. Then do it again. Same experiment: Port the head, install the valves and test on a flow bench and then on a 350 test engine. Even compare other heads to the heads you did, on the same 350 engine. Put it on a dyno, run it down the drag strip, run it around a dirt track, hell just run it around on the street and see how you like it. Good or bad. Better or worse. than a stock head, than a vortec head or any other head you can dig up, beg borrow or steal. Bolt hem all on a try them out. good or bad expensive or cheap. Test your heads, try a few friends best or worst efforts. In other words put it to the test, yourself. Until you have DONE IT YOURSELF you don;t know. If/ when you were to actually do it for yourself, you will find your result will be real close to everything I said it will be. Hell, maybe better. To start, just do one intake port on the head and get it flow tested. rough in a 1.94" valve job and test with a old 1.94" valve on the flow bench. Come back here and tell me I'm wrong. Try to disprove it. By doing it. I don't need your qualifications.. I trust ya. Note: When you have done that,, we can compare qualifications. Last edited by F-BIRD'88; 12-29-2012 at 02:28 PM. |
In fact go thru any of my old posts and follow the specific advise, recomendation, or recipe I offered,
exactly as stated, on what ever that question or problem was and DO IT YOUR SELF. And bring the results back here, YOUR RESULTS. In other words DO it your self and try to see if it came out any different than I said It will. Try to disprove what I said or advised. By doing it yourself to either prove it or disprove it. We'll be waiting. Last edited by F-BIRD'88; 12-29-2012 at 02:47 PM. |
The difference between me and Bydggy and you, is this.
We have both done this, ourselves. Already. And you have not...yet... Thats a big difference. And all the qualification needed. |
No, the difference between you and I is I'm smart enough not to waste my time trying to turn boat anchors into gold.
Yeah, just as I thought. No qualifications or certs to back up what you say? Did you even graduate from high school or have you spent your entire life on here accumulating 7300 posts on here acting like you invented the internal combustion engine? I hear there's an ignore list. You're on it for sure and I hope others put you on theirs. You just give plain old bad advice with an attitude. |
Kid, you are clearly ignorant, F-BIRD'88 is a wealth of knowledge here.
You should take some time and refer back to some of his numerous posts and you will realise that his opinions are matter of fact and that advice that he generously offers to people here is good advice that actually facking works! He has helped me and others tremendously. This thread has gotten way of track and I hope the OP has gotten the information that he sought and some giggles along the way! Duke |
| The Following User Says Thank You to thinwhiteduke For This Useful Post: | ||
Gary you can try to actually break a Stock General Motors made 350 SBC crank shaft using a Weiand 177 blower on a 350 YOU BUILT, Tested and Broke that crank shaft, YOURSELF.
Bring us that broken crankshaft, broke in that matter I stated, by you personally. I'll be here waiting too. Finding a crankshaft that has a crack in it and finishing it off with a big hammer does not count. Has to be a stock GM 350 cast crankshaft that was broke by running it in YOUR 350 using a Weiand 177 supercharger on that motor. Last edited by F-BIRD'88; 12-29-2012 at 04:48 PM. |
| Need ya'lls opinions on SBC heads | Camaro_Nut2001 | Engine | 38 | 11-17-2012 08:32 AM |
| need advice ...bad. | rrmike | Hotrodders' Lounge | 1 | 04-11-2006 01:46 PM |
| Bad advice | lluciano77 | Engine | 28 | 03-09-2005 06:33 AM |
| Just bought a 1966 440 pretty bad shape. | Journier | Engine | 4 | 06-07-2004 02:21 PM |
| Need timing advice real bad | 54 Chevy | Engine | 4 | 07-25-2002 07:09 PM |
