Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need ya'lls opinions on SBC heads
Old 11-01-2012, 10:15 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
If your camels are ported,you better port the patriots also.The aluminum heads are lighter.with out putting them on a flow bench it just a guess.With that hydraulic cam and 600s you are limited there also. should make a tonne of mid range power
The Following User Says Thank You to vinniekq2 For This Useful Post:
Camaro_Nut2001 (11-02-2012)
