Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need ya'lls opinions on SBC heads
  #19 (permalink)
Old 11-04-2012, 01:52 AM
BigEd36's Avatar
BigEd36 BigEd36 is offline
Here's a link to an online cam degree calculator that you can use to determine the intake closing angle. Using this in conjunction with the United Engine & Machine online DCR calculator will give a more accurate dcr than just using the generic "add 15 degrees to the duration at 050" in the dcr calculations. This gives almost identical results as the Pat Kelley calculator. Wallace Racing - Cam Degree Calculator
The Following User Says Thank You to BigEd36 For This Useful Post:
Camaro_Nut2001 (11-04-2012)
