Need ya'lls opinions on SBC heads
Hello fellow hot rodders, I built a .030 over 350 flat top motor instead of the 327 for my '68 Impala. The motor hasn't been decked or anything just the overbore. I put my "186" camel hump heads on it that have been cut 0.010, previous owner ported to the max, on the runners anyway, 2.02/1.60 valves, screw in studs and guide plates. I'm running an Isky 284 Mega cam, 236/236 @ 050/ 0.510/0.510 lift on a 106 LSA with matching springs. I went with Doug Herbert anti pump-up lifters. Pete Jackson geardrive, TH400 with a Hughes 3500 stall and running a 3.73 gear, will be changing to a 4.10 over the winter months. After breaking the cam in I found one lifter that is bad, bleeding down very fast, so I pulled the intake, Tunnel Ram with two 1850-2 600 Holleys, and am going to replace all the lifters. Well, right after I built the 350 and put it in the car I ran across a 400SBC thats standard bore and it came with a pair of brand new, new style, Patriot Freedom heads for a super good price so I bought it. Now, i've got the intake off my 355 to put the new lifters in so my question is, do I leave the "186" heads on it or would I be able to tell a large difference by putting the aluminum Patriots on? If so, now is the time to do it lol. I haven't driven the car much at all due to the bad lifter but when I did drive it down the road, that's when the ticking started, the motor has very good power. This is my weekend toy for next year and it will be on the drag strip very little for tuning purposes and to have fun with my buddy's. My next build is gonna be the 400 for my S10 with just an RV cam and a good set of heads as it's going to be a semi daily driver. I value ya'lls knowledge alot and have done a whole lot of reading on here. Thanks
Putting new lifters on a used cam is a very iffy proposition. I'd rather you work on the lifter that's bleeding down- it might just need cleaning. More here.
There may be a lobe going bad on the cam. If that's the case, replace it NOW before it fills the engine w/ground up metal. |
I think the patriots would deffinatly breath a lot better than those humps. Have a look at the link below. Patriots seem to be holding there own
Eight Budget Small Block Chevy Heads Tested - Car Craft Magazine |
If they are the Patriot Freedom heads 2168 with the 185cc runners they should work real well with your 355 motor. The 64cc chambers with the flat top pistons will have about 10:1 compression which is good for aluminum. I would be worried about detonation with the iron heads especially after being milled. Be sure to have the matching valve springs for your camshaft installed on the new heads. If you install new lifters get some 30w Royal Purple break-in oil. Do the cam break-in procedure for about 20-30 minutes at 2500 RPMs. When changing oil after break-in use 10w30 or 10w40 oil with the ZDDP additive and a good filter. When time come to build the 400 motor you will need a set of heads with about 210-215 intake runners.
I second that cdminter59. If you read that article you will see that the patriots made 40 more HP than the vortecs and the vortects are superior to cammel humps. If it were me Id bolt the patriots on if they have a 185cc runner.
I have a pair of "461" heads, "041" and another pair of "186" if I don't find a good pair of Vortecs. Out of the three, which do you think would do the best on the 400 with a .030 overbore?
If your camels are ported,you better port the patriots also.The aluminum heads are lighter.with out putting them on a flow bench it just a guess.With that hydraulic cam and 600s you are limited there also. should make a tonne of mid range power
I agree w/the others on the Patriots- use them as long as the intake runner volume isn't too large for the 355. Should be worth a good bit of power, especially lower in the rev range if the fuelies are fully ported. Also the aluminum heads will give you a bit of a cushion against detonation since they shed heat better than iron heads plus they are probably not milled down like the fuelie heads now on it. They should let you run pump premimum w/o needing to take any total timing away. At least, try it that way because removing max power timing is the most ineffecient way of dealing w/detonation. In case you're interested, there's a page on quench you might get some ideas from. |
With the intake off,the car down for the winter,swapping on heads,your haft way there to be sure about repairing the problem.Might be best off by replacing the cam and lifters.
Pay attention to the compression ratio- a 64cc chamber on a 400 SBC w/flat tops and a tight quench can exceed 11.5:1- higher than pump gas will allow w/o detonation. A 22cc dished piston will put you at about 9.75:1, the absolute limit I would recommend using iron heads- and even then the cam has to be chosen carefully so the dynamic compression ratio isn't too high. Calculators Static compression ratio *Interactive JavaScript to Calculate Engine's Compression Ratio (CR) Dynamic compression ratio *Dynamic CR *United Engine & Machine Co. Incorporated You should CC the heads to be sure that each pair are the same, and that none were milled excessively. Even if they are as cast and never been milled, the chamber volumes can vary from published figures. |
| All times are GMT -6. The time now is 01:12 AM. |
