need your oppinion please. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2002, 04:10 AM
Post need your oppinion please.
I have a "92" Pontiac, It has the six cylinder in it and a automatic 4 speed. When it is in drive it shifts great, but if I pull it down in to 1,2 or 3 it is slipping real bad, like it is in neutral! In reverse it seems to have a jerky feel to it, almost like a standard when the clutch is let out to fast!
What could be the cause of this and do you feel that some one that has no experience on automatics would be able to fix this problem? I do have a lot of experience on motors and standard trans. though.
Old 06-15-2002, 02:25 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
this is just an idea, but i think i would check the shifter linkage. is your car mechanical or cable-operated? If it is cable, then maybe it needs to be adjusted or something.
JB
Old 06-16-2002, 12:21 AM
E.T. divided by $ spent= Speed
Post
Pull the dipstick and smell the fluid to see if its burnt.
Old 06-26-2002, 07:23 AM
lamothe1's Avatar
Post
if it shifts good while in drive the clutches, seals & bands are ok. it must have something to do with the linkage because you are using the same gears, just that you are doing the shifting manualy.
Old 06-26-2002, 11:59 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
How long since it has bee serviced? May be a plugged filter. Get a Chilton's and adjust the linkages per their instruction.
[ June 26, 2002: Message edited by: willys36@aol.com ]</p>
