need your thoughts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2004, 11:06 PM
need your thoughts
I have just purchased a 74 vega, its tubbed,has narrowed 12 bolt,roll cage, and it set up for a small chevy.I have a two bolt 400sb laying around. Would I be better off having my block prepared to bracket race "4-bolt caps, etc."? or purchasing a dart block with the stuff already done to it. It will be a weekend strip toy for bracket racing.Not interested in being the fastest car there, more like consistant and reliable. Thanks for your thoughts. Joe
Old 03-22-2004, 11:42 PM
poncho62's Avatar
Wiki Edits: 5
If you want consistancy, keep the 400, 2 bolt mains will be OK, put in an automatic, shift it at 5200 rpm and it will run good and the same all day long.
Old 03-23-2004, 02:25 AM
Thanks poncho, what horsepower level can the two bolt blocks be built to?
Old 03-23-2004, 05:03 AM
OddRodder's Avatar
CORNFED and INBRED !?!
You should be able to make 450h.p. live in a 2bolt 400 block. If you are worried though, stud the mains with quality fasteners like ARP!!
Old 03-31-2004, 02:28 PM
What is a safe hp/rpm range for the 2-bolt 400 ,with the main stud kit."I am looking at the 12.5-1/ 415ci eagle kit" Is this doable in my 400 with the main kit? "this will power a vega 1/8 mile bracket car.Thnx. Joe
Old 03-31-2004, 06:30 PM
poncho62's Avatar
Wiki Edits: 5
If you want consistancy and reliability, you will go with about 9 to 1 compression....12.5 is wwaaaaaayyy too high.
