Need your thoughts.. Engine trouble - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-21-2008, 08:21 AM
Technical Support Barry Grant
Originally Posted by camaro freak
After driving the car for about an hour I pulled a plug to read it. It looked much better than the other plugs. After studying the plug link and making comparisons to the pictures I would say that the Holley is only slightly rich and I need to bring timing down to around 14 deg advance from 16 degrees, but really the plug is very close to looking like the picture of best. Now here is a question for the BG tech! If the BG Mighty Demon carb I have listed on eBay don't sell can I replace the metering blocks with a set that is leaner or is changing the jets all that can be done?
The Mighty Demon has an adjustable idle feed restrictor as well as adjustable idle air bleeds so if the idle circuit needs to be leaned out it can be done by a combination of both.
  #47 (permalink)
Old 07-21-2008, 01:33 PM
BG Tech...
Ok, if it don't sell I will call you folks to see what I should do. Thank you to all!!!
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Hotrodders Knowledge Base: Engine Jon Engine 0 11-26-2005 06:17 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Engine Trouble Joe_Marine Engine 4 10-30-2003 04:14 PM
