Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need your thoughts.. Engine trouble
  #32 (permalink)
Old 07-11-2008, 05:48 AM
n-gin's Avatar
n-gin n-gin is offline
BrraaAAAAP!
I believe that gm used nine different balancers too. So make sure it is the right size and degree. I ran into this problem with the Performer rpm engine I built.
They had three timing locations 30*,10*, and 0*
PART No.
ENGINE
HUB SIZE
BAL SIZE
TDC LOC
DESCRIPTION
364709
302-327-350
6-1/4
8 x 1-3/4
10-Deg
Nodular Iron, Off Road
458653
267-305
4-3/8
6-3/4 x 1-11/16
Base Performance
3817173
302-327
6-1/2
8 x 1-11/16
2-Deg
High-Performance
3947708
302-327-350
6-1/2
8 x 1-3/4
10-Deg
Special Hi-Performance
6272221
305-350
4-3/8
6-3/4 x 1-3/16
10-Deg
Base Performance
6272222
350
6-1/4
8 x 1-1/2
Intermediate Performance
6272223
262-307
4-3/8
6-1/8 x 3/4
Base Performance
6272225
400 ONLY
6-1/4
8 x 1-1/2
10-Deg
12555879
350
6-1/2
8 x 1-11/16
10-Deg
Used on LT-1, Z-28, L-82, and ZZ4
Fig. 44.2
There are three locations for the Timing Mark on the Harmonic Balancer. The early style balancer Pre-1969 have the Timing mark 2-degrees before the key way Center Line. The second Timing mark used from 1969 through the mid 80' is 10-degrees before the key way Center Line. The third Timing mark used is 30-degrees before the key way center line.
