Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need your thoughts.. Engine trouble
  #39 (permalink)
Old 07-20-2008, 08:57 AM
eric302's Avatar
eric302 eric302 is offline
Why be normal?
Before you get rid of the Demon make sure you are getting a good shot of fuel from the accelerator pump. You should be able to see the fuel come out of the squirters when the throttle is activated. If there is no fuel from the squirters check the accelerator pump or the adjustment. I've been there. Just my 2 cents worth.
