Needed Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2007, 10:41 AM
Needed Help
Here's the promblem, got a 83 mustang and plan on using chev motor, wanting to make at least 300 RWHP , motor is 350 sbc bored .30 over with 350 turbo trans, car has 7.5 rearend with 373 gears,working with budget, was planing on using 882 heads but heard there prone to cracking, intake is street dominator with 650 holley carb, but may not use if i go with different heads. Thinking about using vortec heads, so have to get new intake as well, but any suggestions on how to make the power build up or which parts to use would be great
Thanks
83 Chevstang
Old 09-18-2007, 03:10 PM
DoubleVision's Avatar
Before I did anything I would first do a mockup fit with a raw block with heads on it to see how to route the exhaust. Some guys did that here many years ago, and the header fabrication was a very slow process, cut and try.
Why Residual Valve Needed??? Mel Smith Suspension - Brakes - Steering 4 05-18-2007 09:21 PM
Any Machining Needed For 6" Rods In A SBC 400? NitrousJunkie Engine 2 06-27-2006 05:29 PM
help needed savman1 Engine 4 06-15-2006 11:58 PM
spring perch no welding needed ??? Can drive 55 Transmission - Rearend 1 10-07-2005 08:36 PM
what size rim, slick width and backspacing are needed? sb72elcamino350 Transmission - Rearend 3 06-22-2004 05:16 AM
