Needhelp with Quadra-Jet part number - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2007, 11:37 AM
I just bought a Quadra-Jet from a friend recently, and I ran into some trouble trying to identify it. I found the part number on the side, and did some internet searching to try and decode it. I found a wealth of information, but none of it matches up with whats stamped on the side of the carb.
The number is 17054919. I know the 170 is for '76 and later carbs, and the next two numbers (54) stand for the year produced. On every website I've found, these two numbers are not listed in this sequence. I'm also having trouble with the next number, 9. It is my undrstanding this is the model number, but all the information I've found only has meanings for numbers one through six.
Any help on this at all is greatly appreciated.
Old 10-21-2007, 01:30 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Looks like a factory replacement or a crate motor carb. All bets are kinda off in that case. The 9 emissions code usually was what they used on smog-exempt crates and warranty replacement.
Old 10-21-2007, 07:03 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Look in the KnowledgeBase,
http://www.hotrodders.com/kb/carburetor
Luv the smell of NITRO in the morning.
Old 10-22-2007, 01:21 AM
Thanks for the help. Any ideas on rebuild kits for it? I tried looking on Summit, but I'm not sure which (if any) is the correct kit.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Cam Part Number specs Pgraphix Engine 2 05-26-2004 01:42 PM
piston part number confusion Sleeve396 Engine 0 04-13-2004 09:03 PM
Need help with part number mitmaks Engine 3 01-17-2004 10:41 PM
