Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Needing a 4speed tranny for my 54 ford pu
Old 12-28-2012, 05:52 PM
bill plise bill plise is offline
Hi, I want to install a 4 speed in my 54 ford pick up but am not sure what unit to use. Im presently running a 302 86 ford motor [not a 5.0] and a AOD transmission. I believe they use to use a T10 in the early ford muscle cars but I was wondering if the muncie or saginaw can be used in its place? are the mounting holes the same? lenght and spline # of the imput shaft the same? what bell housing would I need to use? I would also like to use a hydraulic throw out bearing instead of linkage and fork, is this a posibility on the early trannys? any imput would be appreciated. Bill
