NEEDING HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2002, 02:47 PM
Post NEEDING HELP
HAVE A 67 283 AND I CAN'T KEEP A FLYWHEEL OR STARTER ON THIS MOTOR AND IT ALSO RIPS OUT THE FRONT PUMP ON THE TRANSMISSIONS. I DON'T UNDERSTAND WHAT IS WRONG; HELP
NEVER HAD THIS KIND OF PROBLEM BEFORE ON ANY MOTOR
Old 09-14-2002, 03:25 PM
NAIRB's Avatar
Post
Has it been align bored excessively?
Old 09-14-2002, 06:52 PM
aka Duke of URL
Question
How about the crank center thrust bearing? Does the crank have excessive front to rear movemant?
Maybe a bent or out of round flex plate - convertor not fully seated in pump?
Old 09-14-2002, 07:11 PM
woodz428's Avatar
Troll Hunter
Post
The align bore question is a valid one. But is the engine a known quantity ( has it been used in another car prior to your's without problems)? If so is then the same question for the tranny. Finally if the motor was used in another vehicle before without problem was it a stick and if so did the pilot bushing in the crank get removed prior to installing the automatic?
