needing help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2006, 07:17 PM
needing help
i built a 389 Ci Pontiac engine and installed it in my son's 85 Chevy 4x4. when i got the engine from the machine shop i noticed the dipstick tube no longer extended below the block so therefore the dipstick hits the crankshaft. can anyone help me find a dipstick and tube for this engine? Can i build a tube from steel brake line? what would the measurement for the tube be? any and all help in this endeavor will be greatly appreciated
Old 06-07-2006, 07:28 PM
389 dipstick
Did you look at Ames engineerings catalog or website?Lots of Pontiac stuff.What a cool engine swap!Must have lots of grunt.My 64 Bonnie was a stump puller!
Old 06-07-2006, 07:38 PM
I just got through doing a 428 Pontiac and there was a short tube that went up into the stick tube that goes through the block at the oil rail, it was a sweeping L and it extended through the windage tray to keep stick away from crank.
Cant remember how the 389 was configured , many moons!
New Here and Needing help candysdave Introduce Yourself 1 05-26-2006 01:51 PM
needing help with primers 38 old coupe Body - Exterior 2 09-04-2005 10:37 PM
Needing AOD interm clutch set the clgauge thickness macx Transmission - Rearend 2 11-21-2004 08:03 PM
needing a little help picking out headers mathjew Engine 5 10-13-2003 07:09 PM
NEEDING HELP AUSSIENUT Engine 3 09-14-2002 07:11 PM
