needing help with valve covers. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2013, 01:12 PM
Slammedsi's Avatar
I'm looking for a set of zinc plated tall valve covers for a sbc I'm building. The problem I'm having is, all I can find are circle track valve covers that are zinc plated. If I can't find any normal covers, will it be ok to run circle track covers on the street? This is not a daily driver.
Old 06-08-2013, 04:09 PM
327NUT's Avatar
Circle track covers will work, if they're the ones with the 2 breather tubes on one side then install 2 breathers of your choice and a pcv unit on the other side.....it's a must have to keep your engine happy
The Following User Says Thank You to 327NUT For This Useful Post:
Slammedsi (06-08-2013)
Old 06-08-2013, 05:41 PM
Slammedsi's Avatar
Ya. If I can't locate a normal set I will go with the circle track covers.
Old 06-09-2013, 06:12 AM
Slammedsi's Avatar
Moroso Stamped Steel Valve Covers 68366 - Free Shipping on Orders Over $99 at Summit Racing
Looks like this is the only option out there.
Valve covers vance pointer Hotrodders' Lounge 12 12-10-2009 03:09 PM
Valve covers. mrdreex Engine 17 11-13-2008 12:52 AM
Need help ... What are these Valve covers from? old69 Engine 15 03-24-2005 07:07 AM
EGR Valve in the way of new valve covers Jag Daddy Engine 9 05-16-2004 11:05 PM
Valve Covers comet boy General Rodding Tech 2 11-01-2003 11:39 AM
