Needing "Pull Power"! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-06-2013, 03:03 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Joe'sRedMule View Post
nick8, itís a 350 set in front of a 400 t/h with 4:56 gears. Iím sure that the tranny is in good condition but the domino effect of a stronger engine vs the same tranny might bring about adverse effects as well.
The TH400 was used behind some pretty stout big blocks from the factory. I don't think I'd worry too much about it being behind a warmed-over 350.
The dual plane intake I was referring to is an aluminum high-rise that I have laying around.
Does this intake have any name or numbers on it?
  #17 (permalink)
Old 12-06-2013, 07:32 PM
Yes ... says Made in China on the bottom. Nothing else. It was used when I got it for cheap.
  #18 (permalink)
Old 12-07-2013, 03:51 PM
Wiki Edits: 326
At the bottom of the page on this link is a diagram showing how to measure the height of your intake manifold. The figures that are shown in the diagram are for a standard low-rise Performer intake manifold. Measure your intake and post the figures, then we can determine the rpm range.....
Edelbrock.com - Intake Manifolds Introduction
  #19 (permalink)
Old 12-07-2013, 05:08 PM
Thanks techinspector1!
It's about 10 degrees in the shop right now but I need to head out and warm it up for another project anyway. I read the instructions and I should be able to measure it and post the results in a little while. It has a one inch spacer on it. Not sure whether or not that will stay. I'll measure it and add an inch on both ends or 1/2 over-all and post both measurements-with and without.
I mentioned having a Cloyes double roller that has the option to be mounted either retarded or advanced. I have the cover off but haven't looked yet to see how it was set up. I'm considering using the slot for the key-way that's for advanced. Any ideas?
  #20 (permalink)
Old 12-07-2013, 05:14 PM
vinniekq2's Avatar
reread post #12 and a few before that.I prefer late cam timing to retarded,just me,,,,
  #21 (permalink)
Old 12-07-2013, 05:46 PM
Got it! My highrise is 4 7/8 without the 1" spacer and 5 3/8 with according to the link. And there were some numbers scattered around on the thing as well. I may just zoom in and post some pictures if I bring it in tonight (gotta sneak it past the wife).
And vinniekq2 ... guys from my generation were never confused as to whether it was politically correct to "retard" our timing. But, if it offends you ... then you haven't been in many garages with red-necks a'drinkin' and a' buildin' them thar trucks n tractors.
  #22 (permalink)
Old 12-07-2013, 05:53 PM
vinniekq2's Avatar
lol,Im not offended in the least if your cam is retarded,,,
My cam is "straight" I hope that doesnt offend you
  #23 (permalink)
Old 12-07-2013, 05:59 PM
Wiki Edits: 326
99 times out of 100, you're better off to install the cam straight up, neither retarded nor advanced. What I advise is that if you intend to play with the cam timing, you should make allowances for it in your build. Here's the cover I recommend.....
http://www.summitracing.com/parts/clo-9-221/overview/
Then, use a bolt-on timing tab based on the diameter of your damper.....
http://www.summitracing.com/parts/pro-141-200/overview/
http://www.summitracing.com/parts/pro-141-202/overview/
While you're doing that, verify the TDC mark with this tutorial....
http://www.crankshaftcoalition.com/w...op_dead_center
You'll want to drill your cam gear oversize to 0.40625" and use the desired bushing to retard or advance the cam timing.....
COMP Cams 4760 Comp Cams Degree Bushings - Free Shipping on All Orders @ JEGS
  #24 (permalink)
Old 12-07-2013, 07:14 PM
Then, straight up it is!
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
"Just a little pull is all it needs" Photos from the body shop! MARTINSR Hotrodders' Lounge 9 09-29-2010 10:53 AM
Holley, "needing choke to run" Chevpwer Engine 9 06-12-2009 07:07 PM
Just an "Observation" needing 'clarification' carsavvycook Off-Topic 4 11-02-2008 04:04 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
