Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - needing some advice
Old 09-26-2012, 09:26 PM
chris78 chris78 is offline
the car hooks good with a good burnout and traction bars are all but touching just where their suppose to be i've been told by everyone that has looked at stalling the car at around 2 grand can't really go higher because back brakes need some work and the car starts to push.planning to fix them during off season but only have two races left so making do till seasons done with them.i'm crossing the finish line a 5400 5600 rpm so i dont think gears need to be lowered and im in third by the 330 mark.i ran 26in slicks first few races and my et has stayed within a couple of hundreds.lower gear would take the car out of the power range woundn't it? i know the heads aren't idea planning to go aluminum if money is there this winter.same with cam planning to go with a 280 solid lift also. i have run against similar set ups and always seem to be 2 to 3 tenths slower but 3 to 4 mph faster then them.not looking to be king of the class but running points next year and just want to be in the middle of the pack.fastest cars running 7.20s slowest 9.0s hoping for low 8s and the maybe spraying it if a want to run 7.50 index next year to.
