hopefully have alittle more info after saturday.going to pull and reinstall distributer tomorrow and if my buddy can make it over going to work the back brakes over then head to the track saturday.mulligan race with lots of cars so maybe i can get several pass in and i'll try watch my mph and shift points on the track.also found one of my plug wires was not hooking on the cap good.fixed it so hopefully the car should run alittle better and we can go far.
just being able to load the car under its own power has been a bonus this season.my buddies are getting tired of pushing.really got them a few races back when i ran my truck in eliminations because car broke and ended up taking home second at their expense.
got the timing fixed it was a tooth off.car sounds goods keeping fingers crossed for tomorrow.couldn't get the brakes fixed though parts didn't make it in.they will have to make it through one more race.
hi chris, names charles, I also have a vac. sec. carb. and have gotton great resaults with changeing the springs, also been reading about dist. timing. had it pulling and tryed a step lighter spring and was ready to go back to the spring before when i added bit more timeing the truck came ALIVE, i've got a 350 w/a 350 trans, holley 650, mallory dist w/a accell coil. its alot cheaper and easier then changeing gears.
well my luck held up my bad luck that is.when my buddy help my time the car he didn't get the wire on the dist. good.result first time run did burnout rolled up to stage car dies.
![]() ![]() ![]() push it to the pits and discover the problem and fix.second run tach goes crazy and is all over the place think its shorted out its jumps all over the place.no idea what to stall to or when to shift.still run 8.53 e.t.fastest pass car has made. first elimination bad light car falls back to a 8.61 but other guy broke out. 2nd elimination get out of it alittle thought i was running to fast bad mistake she caught me at the line.there goes my mulligen. 3rd run over a tenth fast dial then other guy,have great light,and catch him right at the 330 and get out of it car runs great and goes 8.64 off the pedal at about 3 lenghts fomr the line. ![]() ![]() ![]() 4th run other guy starts lose water after burnout and is out,bye run go to stage no gear,lost the tranny in burnout.no gears in anything think pump must of went. ![]() ![]() thats race'in for ya and we still love it.Could this tranny problem possible why the car has't been running like i thought it should? |
missed choctaw bob's post somehow.what changes should be made to back of car.I've been told smaller slick but a ran 26in slicks earlier in the year bought this 28's at a swap meet cheap and they only had about 20 passes on them and started running them and if they've done anything its picked the car up on et.i know their slowing down my take off but they are helping my top end.aiming for more mph and lower et.
when ours are about done we usually use them in local burnout contest and most of the time not much left after its over.sometimes sell them to another guy that just wants a spare set of slicks in case you get a flat at the track.
Or sell them at a swap meet. A pair of slicks that have 20 passes over the last 10 years are no bargain. Always run new. A new pair of drag radials are better than old, hard slicks.
we get ours from shootout racers that buy new slicks after two or three races.the ones the sell are only a couple of months old and usually are 3/4 of the wear still on them.my last set the guy had one night of testing on them and then one race.gave $125 for them and they would of cost $400 new and they were only three months old.
That kind of deal is the rare exception where you know the entire history of the tires.
| Tags |
| 350, chevy |
| needing advice on swapping 95 tbi to a vortec | joshuabrodie | Modern Electronic Engines | 5 | 03-04-2012 12:04 PM |
| needing some advice on gearing for my jeep | inquiring_mind2 | Transmission - Rearend | 15 | 06-19-2010 02:21 PM |
| New guy needing advice before I drive myself NUTS!!!! (355 build options) | Chevy Eleven | Engine | 12 | 10-19-2009 01:58 AM |
| Chevy 302 Buildup--Needing some advice! | Jeremy McGlade | Engine | 12 | 03-06-2004 09:07 AM |
