Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - needing some help
Old 03-27-2013, 09:39 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
If you are sure the engine did not flood out, I would suspect ignition. If you have a real weak spark, it may not be enough spark to fire under compression. Are you sure mechanics are good? Possible timing chain jump?
The Following User Says Thank You to 33Willys77 For This Useful Post:
gmcjake89 (03-27-2013)
