Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - needing some help
Old 03-28-2013, 09:21 PM
cdminter59 cdminter59 is offline
needing some help
If you have a HEI distributor in it pull the module and take it to Auto Zone to have it checked. With the yellow fire most likely its died. Here is an article on HEI distributors. It will explain how to test the HEI components. http://www.crankshaftcoalition.com/w...EI_distributor
The Following User Says Thank You to cdminter59 For This Useful Post:
gmcjake89 (03-29-2013)
