-   -   needing some help (http://www.hotrodders.com/forum/needing-some-help-231234.html)
gmcjake89 03-27-2013 06:57 PM
needing some help
ok guys heres the deal, ive got an 85 gmc 4x4 with a 350 bolted up to a ch465. while out driving around it started sputtering and died as if out of gas when I got in the pedal rpms dropped even more until it died and wouldn't start again. Ive checked fuel supply and made sure the carb is getting fuel and cylinders are wet. not sure where to go next. Spark plugs are almost brand new and gapping is still good but they do look a little fouled out. Where should I go from here?
33Willys77 03-27-2013 09:12 PM
Check to see if you have any spark.
gmcjake89 03-27-2013 09:17 PM
yea I checked I do have spark but its weak meaning its more of a yellow color instead of a blue still seems like it would fire though
33Willys77 03-27-2013 09:41 PM
What ignition do you have? HEI? A motor need gas, air, and spark and it will run - as long as all mechanical is good. Is this a carb motor or injected?
gmcjake89 03-27-2013 09:49 PM
its a carb its a 650 edelbrock and the ignition is stock but I aint had a problem with it before.
33Willys77 03-27-2013 10:39 PM
If you are sure the engine did not flood out, I would suspect ignition. If you have a real weak spark, it may not be enough spark to fire under compression. Are you sure mechanics are good? Possible timing chain jump?
gmcjake89 03-27-2013 11:23 PM
alright im hoping its not the ignition thanks for the input
cdminter59 03-28-2013 10:21 PM
needing some help
If you have a HEI distributor in it pull the module and take it to Auto Zone to have it checked. With the yellow fire most likely its died. Here is an article on HEI distributors. It will explain how to test the HEI components. http://www.crankshaftcoalition.com/w...EI_distributor
gmcjake89 03-29-2013 08:16 AM
I got it fixed found a lose wire to the distributor and changed spark plugs thanks guys
