needing some help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2013, 06:57 PM
needing some help
ok guys heres the deal, ive got an 85 gmc 4x4 with a 350 bolted up to a ch465. while out driving around it started sputtering and died as if out of gas when I got in the pedal rpms dropped even more until it died and wouldn't start again. Ive checked fuel supply and made sure the carb is getting fuel and cylinders are wet. not sure where to go next. Spark plugs are almost brand new and gapping is still good but they do look a little fouled out. Where should I go from here?
Old 03-27-2013, 09:12 PM
33Willys77's Avatar
Check to see if you have any spark.
Old 03-27-2013, 09:17 PM
yea I checked I do have spark but its weak meaning its more of a yellow color instead of a blue still seems like it would fire though
Old 03-27-2013, 09:41 PM
33Willys77's Avatar
What ignition do you have? HEI? A motor need gas, air, and spark and it will run - as long as all mechanical is good. Is this a carb motor or injected?
Old 03-27-2013, 09:49 PM
its a carb its a 650 edelbrock and the ignition is stock but I aint had a problem with it before.
Old 03-27-2013, 10:39 PM
33Willys77's Avatar
If you are sure the engine did not flood out, I would suspect ignition. If you have a real weak spark, it may not be enough spark to fire under compression. Are you sure mechanics are good? Possible timing chain jump?
The Following User Says Thank You to 33Willys77 For This Useful Post:
gmcjake89 (03-27-2013)
Old 03-27-2013, 11:23 PM
alright im hoping its not the ignition thanks for the input
Old 03-28-2013, 10:21 PM
needing some help
If you have a HEI distributor in it pull the module and take it to Auto Zone to have it checked. With the yellow fire most likely its died. Here is an article on HEI distributors. It will explain how to test the HEI components. http://www.crankshaftcoalition.com/w...EI_distributor
The Following User Says Thank You to cdminter59 For This Useful Post:
gmcjake89 (03-29-2013)
Old 03-29-2013, 08:16 AM
I got it fixed found a lose wire to the distributor and changed spark plugs thanks guys
350, 350 problems, fuel system, spark plugs
Needing help. GMCTRUCKS Electrical 6 01-26-2008 08:45 AM
needing help rhb7/22 Engine 2 06-07-2006 07:38 PM
New Here and Needing help candysdave Introduce Yourself 1 05-26-2006 01:51 PM
needing some help please Aberium Hotrodding Basics 5 01-29-2004 09:12 PM
NEEDING HELP AUSSIENUT Engine 3 09-14-2002 07:11 PM
