Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - needing some help please
Old 01-29-2004, 07:39 PM
aka Duke of URL
I am assuming that what you have in there now is an early 302? And you want to upgrade to a later 5.0L (carb or FI)?
It should slip right in. There were no major changes between the years. The only problem that you might run across is there being no mounting hole for the clutch bar on the later 5.0 but there is a kit to remedy that.
If this didn't help or answer your question, hit me up again...
