Needle's - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2011, 11:24 AM
Needle's
WITCH is the best needle to use for enamael 1.3 1.8 any help!!!! HVLP startingline
Old 01-23-2011, 11:42 AM
Which witch you referring to, the good witch or the bad witch?
When spraying enamel I use the 1.4 setup; but, the 1.5 would be more appropriate.
Old 01-23-2011, 11:44 AM
deadbodyman's Avatar
Wiki Edits: 11
I'd have to say the 1.3 because its closest to the 1.4 ...the 1.4 works great,I never used a 1.3 but the 1.8 is for the thick primers last week I used a 1.5 for the first time and I really didnt like it (too big) with the 1.3 you may have to add a little more reducer....
Old 01-23-2011, 12:02 PM
The 1.3 will work if all he has is those two options; however, the 1.3 tends to apply enamel too dry leaving a hazy finish which can be corrected with a cut and buff.
Old 01-23-2011, 01:19 PM
Needles
Thank's Guy Will Hopefully Help
