Neer Recomendation on Front Steer Spindloes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2012, 06:37 PM
I need recommendations for a car model that uses strut type front suspension with spindles that have the steering arm forward of the front spindles steering axis. I plan to retrofit the strut assemblies into a 3300# PT Cruiser being converted to RWD. It would be a plus if drum brakes were available for these spindles and 5 on 4.5" bolt pattern would also save effort. Part of the plan is to replace the lower control arms so there is no need for compatability with the stock PT control arms .
PS -- If anyone else ventures this path a front clip might make a lot more sense, but it is too late for me.
Old 05-26-2012, 02:50 PM
NEED, not "Neer" --
Old 05-26-2012, 10:17 PM
Wiki Edits: 27
5.0 mustang
the 5.0 mustangs use front steer and Lincoln 5 bolt 4.5 hubs fit on 87 and later but are disc, they make a tubular crosmember for racing 5.0's I think hotrod magazine had V8 PT"S google it.
Swapping spindles for front to rear steer Mutt's37Buick Suspension - Brakes - Steering 6 07-23-2011 08:34 AM
Front Steer Conversion v123 Suspension - Brakes - Steering 5 01-09-2011 03:30 PM
Front steer power rack. slyhog22056 Suspension - Brakes - Steering 9 09-07-2008 02:29 PM
front or rear steer knighthawk Suspension - Brakes - Steering 2 11-20-2006 01:10 AM
can you swap front-steer and rear- steer? (Nova) old69Nova Suspension - Brakes - Steering 0 10-06-2002 08:20 PM
