Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Negative camber question
Old 07-02-2010, 09:00 AM
impalaman63's Avatar
impalaman63 impalaman63 is offline
I have a 1963 Impala with negative camber (both tires on top tilt in)
Is this because the springs are getting old and the car is starting to sag?
Can I correct this with shims on the A arm?
I know I should replace the whole front end, but for now, I need a quick fix.
Also, if I put shims in, do I put equal # of shims on each bolt?
(photo not my frame)
