Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Negative camber question
Old 07-02-2010, 02:19 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Adding shims will make your camber situation worse, you need to remove shims as you have to move the top of the spindle outward to remove negative camber. The offset upper A-arm shaft is frequently needed to accomplish this as usually you will not get enough camber removed before you run out of shims to remove.
