Ner rocker arm ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2004, 03:19 PM
I want to upgrade my stock 1.5 rocker arms with some new 1.6 comp cams hi tech stainless units. will i have any clearance issues with springs, piston hitting valve, push rods etc? will the gains be worth the money? i have a 74 camaro 350cid LT-1 block 100% stock internals. and would i be have 3/8 or 7/16 studs thanks?
Old 01-30-2004, 08:24 PM
High Tech SS rockers on a totally stock motor is overkill.
Personally, I would use Magnum roller tip or Pro-Magnum Steel.
Comparing prices in CC's web catalog, I found this:
#1416-16 Magnum 1.6 .... ... 219.04
#1302-16 Pro-Magnum 1.6 ... 344.96
#1102-16 Hi-Tech SS 1.6 ... ... 456.16
You may find these #'s for less, but the price difference is still there. You lays down yer money and takes yer pick.
Oh, and you have 3/8" studs.
Old 01-30-2004, 10:50 PM
lluciano77's Avatar
You may have to use Luis tool and enlarge the pushrod slots. That becomes necessary around .480" lift.
Old 01-30-2004, 11:29 PM
rifraf's Avatar
I bought a car with magnum 1.6 rockers on it,they were almost new,the roller tips went flat and caused intermittent ticking,not impressed.
