Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it nesary to degree my cam?
Old 03-25-2011, 04:56 PM
spinn's Avatar
spinn spinn is offline
No, you can install a cam. dot to dot.
If you are ready for cam installation, and verified TDC. The cam gear mounts on a peg , oriented 90 degrees CCW, cam dot down. After setting the gear positions turn the crank a few times and see if they still line up. To be only a tooth off is very noticeable.
