Netural Safety switch
I was wondering if someone could help me with a starting problem. I have a 69 Corvette with a dragging starter. I checked the battery and is was weak and couldn't be charged up so I replaced it thinking that was my trouble. The car started ok, at times and then was dragging again. I replaced the started with a new gear reduction starter and again thought everything was fine. Trouble returned and now it won't even crank at times. Someone told me it could be a netural safety switch problem. Were is that located and how can I check and replace it. Is it hard to get too and what does it look like. I'm new at maintaining this car but love doing it, when I know what to do.
Chances are, it's a heat problem. The exhaust is so close to the starter, that the heat is affecting the starter solenoid.
Dose it just give you trouble when the engine is hot, or all the time?
Ontario Rodders |
It does it whether it's cold or hot. Sometimes it starts fine, sometimes draggy and sometimes it's dead.
Well, then I change my vote....
I would be looking at the starter. Possibly, the bearings are shot, the arnmature is moving around, causing different symptoms. Another possibility, is that the ground straps are not solidly connected.
Ontario Rodders |
Check all your grounds. You should have one from the block to the frame, and also check the negative battery cable to see if it is making a good connection both at the battery and at the grounding point.
Ground
Doc here,
It sounds like (especially on a Corvette) Grounding issues.. First Is your battery box located on that year under the hood, or behind the drivers seat? Second, Check Both your cables, BE sure they are Clean, tight and do not have corrosion under the insulation.. Third, you need to check the ground system..remember the engine sits in a plastic car, on rubber mounts... Your ground should be set up as such, The battery cable should ground to any handy bolt at or near the starter, from there, get a battery cable that has 2 3/8 ring terminals on it ($6 bucks at wally mart or auto parts place) and ground that to the frame..From the engine block ground at the starter, run 1 #10 wire to the alternator ground lug or mount bolt... USE proper Star washers, Sheet-metal screws / bolts and locks, and burnish ALL the paint and grease from the grounding areas..this will give you a rugged reliable grounding system that will most likely outlast the car... If the Alternator is powered white Along with the mount, remove both and the hardware, and sand or water blast them back to clean bare metal...then when you reinstall add aluminum wire bonding paste to all hardware and anywhere the mount or alternator touches the block .. This is electrolysis , the mount is aluminum and he block is steel (what the hell were they thinking?)..that powder is an insulator.. It will ALSO dissolve the water pump impeller like a mild acid..so you might want to think about replacing that while you are in there too..(less stuff to pull down again..) BE sure all your grounds are tight... Corvette uses ground on many systems to control a function unlike the rest of the world,Which uses power.. (the starter is NOT one of them..) case in point..the wipers are wired directly hot, straight to the motor and the ground is switched to control speed / washer function control..so on those type circuits, you kinda have to think back-wards from everything you have been taught.. The second Issue with Corvette, Is the ignition switch harness and switch itself, If you have a tilt wheel, the harness running through the column will chafe, or the lower plug will pull loose or corrode..examine those and Clean any corrosion (Big problem on Corvette electrical) The Switch is a 2 part item, has a "snap in " electrical contact bar..check to see it hasn't slightly pulled away from the tumbler assembly..and clean the contact area. One of those should be a cure for the problem. The NS switch should be located in on the linkage near the center console..underneath..Depending whether or not the car is manual or automatic, In MT , you also have a clutch over ride involved.. so both need to be checked. ................................................ ..................................Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thanks for the help guys....
| Wiring Neutral Safety Switch / EZ-Wire Kit | horvath | Electrical | 15 | 01-20-2008 12:35 PM |
| ? about my neutral safety switch in C10 | Streetmaster | Electrical | 4 | 08-30-2005 01:41 AM |
| El Camino/ neutral safety switch | stinky jinx | Electrical | 4 | 03-15-2005 10:00 PM |
| Ford C6 neutral safety switch wire colors | cboy | Transmission - Rearend | 1 | 02-11-2004 05:19 PM |
| neutral safety switch | zipfactor | Electrical | 2 | 08-30-2003 07:58 PM |
