Neutral - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2004, 12:38 PM
Thom Laybourne's Avatar
Neutral
Well I have the truck home and found a broken oil ring in number 8. At first I thought it was the guide. I had to push it into the garage because the transmission would not pull. I removed the cable from the selector to the Hurst and manually placed the selector into low gear. The truck just sat there as if it where in neutral. I can fix the engine, but I am not sure what to look at for the tranny. Fluid is red and no smells. I called the guy I got it from and he told me that the transmission was put in about two years ago. He only drove it on the weekends, so the mileage should be very low. Help. Any ideas? I would like to fix it even though I am going to install a new 700r4.
hr41pearl
