neutral safety - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2005, 12:40 PM
New Member
neutral safety
got the oil in trans and works fine realized no neutral safety switch took cover off hurst rachet shifter and found switch there its depressed when in park assume thats the switch it has 2 wire connectors where does it hook up its a chevy 40 turbo
Old 07-19-2005, 05:14 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
can i get some more info ?? what are we working on?
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-19-2005, 08:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
safety switches are hooked into the starter circuit for the engine.
Do the instructions for the shifter help ?
Old 07-20-2005, 09:27 AM
347mustang's Avatar
run one of the wires from your key switch or push buttom to the netural switch on the shifter and the other to the starter..easy cheeseie
Old 07-30-2005, 09:52 AM
New Member
Neutral Safety
Thanks For The Input Finally Got To It & It Worked Fine
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 01:35 PM
El Camino/ neutral safety switch stinky jinx Electrical 4 03-15-2005 11:00 PM
ford c6 neutral safety wires cboy Electrical 1 02-11-2004 06:18 PM
neutral safety switch zipfactor Electrical 2 08-30-2003 08:58 PM
Neutral Safety Switch NSS C4 Zamteam Electrical 2 12-27-2002 03:44 AM
